Swapping engines on 1200A
464 Views 2 Replies 3 Participants Last post by  GLGREZMONKI
How tough is it to pull an engine on an 87 Aspencade? I think it could be cheaper to just buy a used engine and replace. I am very weary of the engine noise. One shop said the 1200 can have the growl sound and it is normal. I want to take some long trips with it but don't want to break down somewhere, or worse yet have the drive seize up while traveling down the highway. Could end in disaster.
1 - 3 of 3 Posts
If you have the right gear, including a trolley jack and a reasonably competent helper, you can have it changed and on the road in a day. :)
Changing engines is fairly simple if you have some basic mechanical ability, however I wouldnt give up on your original engine too quickly. Goldwing engines typically run without major problems for a very long time. How many miles are on your engine? Does it work ok?Does it burn excessive amounts of oil?Can you better describe the noise that you hear ( which part of engine do you hear the noise from)and do youhave any maintenance history? The noise or growl you hear may possibly be something minor andcan be repaired easily or it may be nothing at all as one shop suggested.I would suggest that you investigate a little further before writing the original engine off and perhaps spending a lot of money that you dont have to............and then if you determine that the engine has some major internal problems for sure go looking for a good replacement............GM
1 - 3 of 3 Posts
