1 - 11 of 11 Posts
On a Wing & a KLR
Need to install a couple of switches on my 1500 but be damned if I can find a suitable location. I've seen those switch blocks that mount on the front brake reservoir but they won't work for me because I need a SPDT switch for my heated grip.
Suggestions, pictures please.
HI:
Also haveSE. Was pondering installingSPST switch or 2 onWing. My proposed location: panel coveringignition switch[mine hasWing's VIN on it]. Panel'seasily removableand there's room enough under it for switches, iflocation is picked with care. My2 cents. TTFN.....Old Tom
Village Whack Job...
Couldn't you just replace one of the SPST switches in the switch box with an SPDT switch?
Or usethis to make your own.
You can replace the ignition cover with one from www.wingmeter.com
Here is what I done with mine. I ordered the blank cover ($59 + shipping). It will be color matched to your bike.
1993 gl1500, 1976 gl1000
Thes are just push button switches but there is plenty of room for toggle switches and easily accessable.
On a Wing & a KLR
That was my hope actually but trying to locate the switch has been a problem. I contacted Cyclemax and they don't have a SPDT available for the switch box.
My son however gave me an alternate idea. I could use the switch box and just use a separate switch for each of the Hi and Low circuits.
On a Wing & a KLR
Discussion Starter · #8 ·
These are both great suggestions. I was contemplating putting the switches in the ignition cover but then thought I would have the hassle of removing the connections to the switches every time I needed to remove the cover.
Wasn't aware of the Wingmeter part. Interesting idea and would give me a place to mount a voltmeter.
Back to the drawing board. Thanks for the ideas.
Just another ORF!
I mounted my illuminated switch for my aux driving lamps on the left side 'dash' panel.
Seeing as I have an Aspencade and not the SE, (no stock CB) I installed a cigarette lighter, the SPDT switch for my grip heaters and a Powerlet outlet for my heated clothing, in the blank CB panel, on the left side of the fairing. Sorry no pic as my bike is back West at the moment.
Dusty
cbx4evr wrote:
Snorebaby wrote:
You can replace the ignition cover with one from http://www.wingmeter.com
I thought of that AFTER I made all those connections on the Wingmeter cover. So my solution....I purchased a repair kit from www.vintageconnections.com
This is the kit I purchased (CK-5). I will run the power wires (from my aux. fuseblock) to a 6pin connection to connectthe powerin one place. Then the "out" wires to the accessories will be connected to another connector. I haven't counted the wires yet to know what #pin connector I will need. But this will accomplish having only 2 connections (maybe 3) to unhookand remove the ignition cover. Plus it will look "Factory installed".;)
On a Wing & a KLR
Discussion Starter · #11 ·
Great idea. I'm a fan of Vintage Connections and never thought of that. I could do everything and have room to spare with a single 9 pin connector.
1 - 11 of 11 Posts
