i assume you have a stock fuel pump . look between the fuel pump and the right head. there is a hole it fits in and the inside bolt on the pump holds it in. remove it so it can go in . also check the flat of the cable that it fits inside of the drive slot of the drive.
I was just into mine, it runs along the upper frame on the left side(with throttle cables) and crosses behind and under the backof theair filter assy. down to the right and onto the drive.
strange , mine runs along the right upper frame and into the drive. above the carbs.
wow did I miss the mark on this one, you are correct, I was looking at the clutch cable. . so sorry if I caused you trouble. and there is a little "clip" on the frame to hold it up , above the carbs too .
Man this getting older stuff sucks!
yeah---- i know. now if i could just rember , what i for got! :ROFL:
