1 - 18 of 18 Posts
OK, here's an odd question. I've decided to do electrolysis on my rusted tank, mostly because I want to try it and see what happens. Here's the dilemma: my lovely wife of 19 years has successfully removed EVERY wire hanger in the house, except for one... The one that her wedding dress is on. So, do I risk eternity on the couch by taking it and replacing with a plastic one, or do I wait till tomorrow and go to the store to get some wire? Don't have anything suitable in the garage right now. Any suggestions or words of wisdom?
If you don't have any safety wire or anything like that... wait til tomorrow.... its safer that way :)
+1 What blackknytecnc
Said. I would wait.
Your wife obviously married you knowing full well of your interest in motorcycles. If she loves you, and I assumes that she does, then she would never get in the way of your love for the bike.
The Choice is therefore obvious... You should take her coat hanger with the confidence of knowing that she would hand it to you herself, if you had only asked her. Don't actually ask her though, as that would suggest mistrust in the relationship.
In the meanwhile you can stuff her wedding dress into the side trunk, for safe keeping, under the tool kit.
2000 GL1500SE
Hey Alex, you trying to get him killed! :ROFL::ROFL::ROFL:
Be a man for once in your life. Use the coat hanger. And then use the wedding dress to clean up your wheels. If she gives you any lip, remind her that she was your second choice.
HERE!!! HERE!!!
Any squabbles, you can always remarry. I hear your Wing is available.
:ROFL:
In the meantime.
Everyone has an old tool that's ready for the trash.
A busted tip screw driver or ratchet extension.
Drift punches are really meaty.
Discussion Starter · #9 ·
You guys are a whole lotta help. Thanks for the good laugh. I needed it. I am currently down one screw-driver...
These guys are going to get you killed, even tho some ideas where very good!! I would (wait). Any type of metal will work ie rebar, old yard tools or any piece of metal that will fit in your tank with out touching the sides. Let us know how it turns out,and good luck. Hal
Piaggio MP3, was 02 GL1800
fatter metal works better than a thin piece of wire.
more surface area, the better it will strip the rust.
A piece of stainless steel works well too, do you really need all those forks and spoons in the kitchen?
Son of Bronson
When I did mine, I used a roll of that perforated iron strapping that they use
to hang plumbing pipes with. I bent it in a curve so it reached into the back
of the tank. I cut a couple of small wooden wedges to use to jam it into the filler
neck without touching the tank. The bigger piece of metal picked up more crap
faster. My tank ended up super clean!
1 - 18 of 18 Posts
