1 - 9 of 9 Posts
The temp gauge on my 1200 isn't working anymore. When I turn the key on everything lights up including the temp gauge but when I run bike for awhile nothing registers on the gauge. Anyone have any ideas?
If you have done nothing to knock a wire loose, I'd bet on the sending unit in the block.
I"m having the same issue on my 83 "A" I taken apart the wires in behind the weight(one of 10,000 wires in there) and cleaned the connector from the digital dash. I've run it a couple times this winter and the gauge has worked. I have a new sending unit ready to install but it looks like a lot has to come apart to change it so I'll see if cleaning it works first.
The easiest and first test is pull the wire off the sending unit and ground it, if the gauge moves up the it's the sender.If not it's in the wiring or the gauge.
That would be the first thing but on on my bike you can't even see the sending unit much less pull the plug off. The thermostat housing or the intake runners would have to come off to even get your hands on it.
Figure out which wire it is, find it at an accessible point, stick a needle through the wire and use a alligator clip and jumper wire to ground it out. Kit
You can disconnect the six pin plug at the left side of the bike after removing the false tank.
It is a 6 pin plug, the wire that you can put to ground is blue with a red plastic tube for ID. There are two grounds (ASPY) make sure that they have good ground connection. One of them is for the Sending unit. On the Interstate there is only one ground as on that model the sending unit is grounded through the engine.
1 - 9 of 9 Posts
