HELLO I have an issue.Ihave2000 Gold Wing SE. my problem is my tempeture guage/ gas gauge and front running lights went out and I cant find a blown fuse or able to trace the problem,are thereany sugestions fellow bikers
Check the relays just to the right of the fuse block (towards the rear of the bike.) That happened to my 96 and it was the #3 relay. Top row, 3rd on right. You can take #1 on left and put it in the 3rd on right and that might fix problem.
Then go to mother Honda and pay $36 for a new 20 amp fuse relay.
Hope this helps. It fixed mine. Usually caused by adding extra lights on scooter.
Can be a bit tricky getting the relay cover off.
Most likely the #3 relay has gone bad. Swap it with the #1 and see if it works.
Sounds like I need to have my computer checked. I think there is an echo in here.:bow:
We must have been typing at the same time.
Yep, but I am a little slower than you it appears.
