1 - 9 of 9 Posts
I have a Terraplane sidecar that I am going to mount to a GL 1200.
If someone has a picture or good advice please let me know. Thanks
I have all the parts from the sidecar out . Where and how the mounts look on the motorcycle will be a big help. Thanks for the link.
Sounds good. Let me know if these pics look like what you have. If so, then I can write up some instructions on how to mount 'em.
Thank you for the link and pictures of the plates that are mounted to the frame of the motorcycle that is what I need to fab. up.
The trick to 'em is that the clvis/hiem joints need to be inline and parallel to the ground. They need to act like the hinge of a door. If you get that wrong, even a little, then the car will be hard to align. The struts act to push/pull the bike to/from the car. The car's wheel should be toe'd in a little and the bike leaned away from the car (about 1-3 degrees from vertical). All those adjustments are made when the car and bike are loaded.
Get ahold of Jay at DMC sidecars. He has those plates ready to ship for $150. You'll need to add the U-bolts and threaded rod to replace the lower engine mount thru bolt. I added a couple U-bolts and i can show ya what I did to give the U-bolts some extra surface. Jay can also advise you on any differences between the 1100's and the 12's. He's a really smart guy and has Ben doing this for years. Will save ya a bit of aggravation.
Jay G
DMC Sisecars
www.dmcsidecars.com
866-638-1793
Something else that makes those plates kinda tough to fab is that they have standoffs welded to the back sides. You can see a little of the standoff peeking out of the top of the front mount in the pic above.
A little paint, some hardware, and you'll have solid mounts set up for straight forward alignment adjustments! You'll see what I mean when you have a set in your hands.
Discussion Starter · #9 ·
When I get the mounts . I will send you a P M .
My plan is to take my time and get it right.
1 - 9 of 9 Posts
