1 - 20 of 22 Posts
Just got all the paperwork together and the title is in the mail :action:
Picked the bike up CHEAP and it has no key
Smells of cat urine:doh:
Best way to start without the key :baffled:
Buy a new switch or call a locksmith :baffled:
Can I pop the tumblers out of the OEM switch :(
I think you can remove the switch part without the wiring, then take the switch to a locksmith and have them make a key for ya.,,
You can get the electrical system fired up by jumpering from the battery to the fuse box.
You can't get the lock cylinder out to get the tumblers out without the key.
Can't help you with the smell though.
Took all my locks to a local locksmith.
Just for Cats, Urine-Off or Wee Cleaner
They all have enzymes which break down cat pee, doubt if they are guaranteed for bikes though.
A real locksmith wouldn't have any problem cutting a key. You should be able to get the code off any lock on the bike.
I came across this link a couple weeks ago, but have not had any experience with them.
http://hondakeys.com
Jim
Discussion Starter #10
The smell of Wee nowhas a corner of my shop, I should have . . . . :gunhead:
I’ll try a locksmith and see if it is in my price range, at the moment I’m a littlefinancially embarrassed :D
Can I take my other 82 key switch and plug it into the 83 harness:?just a thought
Hey SC. I found this stuff @ Homey Dee's called "Oderban",(sp?) and used it on a house flip/remodel which was REAL bad kitty pee smell, and after we sprayed the place, it worked pretty good.Also have used bleach,but it burns everything. Happy resoration to ya brother!! jimwsjinx
More than likely after you wash it,most of the smell will go away. The tires may be the hard thing to get the smell off of. Seems the rubber would hold he smell longer than the metal and plastic. Give it a good washing and make sure you clean out all the nooks and crannies. Then I would try the enzyme type pet odor neutralizer. Natures Miracle is really good and pretty safe on most materials.
Good Luck with your project.
Maybe we should call you "WEE MAN":cheeky1::cheeky1::cheeky1:
Discussion Starter #14
Need to trap a skunk and clear the air a bit ;)
The kerosen blower :cool:kicks it up a notch :(
SC, if it still has the factory helmet lock on the side, pull the lock off and take it to a locksmith. For around $5 they'll cut you a key to fit it.
Take the lock and key back home, replace the lock, start the bike with the new key. :)
Discussion Starter #17
Called and the price was $10.00 eachcode cut and $2.00 blanks
My problem, I counted the locks on the bike :shock: 2 for radio, 5 helmet locks, gas lock, 6 two per bag, ignition, right side glove box
:shock:
Goldwing Addict :-)
Do you have reason to believe that they are all different keys?:baffled:
"factory helmet lock on the side, pull the lock off and take it to a locksmith"
that what I was going to say
Discussion Starter #20
I hope they are all the same :baffled:
I know the starter is toast, in no real hurry
I know the last owner had 5 or 6 Wings and thereis no way to know what isOEM
I just about have the bike apart (cleaning)and I'm working on the tank and breaks, the bike sat for 7 years and has 69xxx miles
The sweet smell of the old gastook the fire out O theWeee smell :cooldevil:
Sweet Peeeee :12grey:inGray the fast-est color
:cheeky1::cheeky1::cheeky1::cheeky1::cheeky1:
1 - 20 of 22 Posts
