I found this little essay on Facebook, sometimes you can come across some interesting reading there.
The Last of The Fast Goldwings ..
4 cyl. not the Land Yacht 6 cyl. ..
.. the last of the 1975-76 by Design High Perf flat four cyl. bike lineage .. is the 1980-'81 GL1100 .
These are the Big Bore 76mm x the RPM loving 61.4mm stroke engines .. with CLOSE RATIO GEAR SETS .
Cylinder Head combustion chambers were re_designed for swirl & better low-mid RPM burn.
Pistons are Flat Top .. heads are cross flow HEMI with valves spaced nicely for seats to stay cool & Tulip Valves.
The GL1100 had three different gear sets in as many years ..
each change moving the RPM range lower for The Touring buyers .. making each gear change wait longer which without adding Torque / HP just makes the bike sluggish.
The change between the Close Ratio 1980-81 bikes & 1982 is big enough for me not to buy a 1982.
The Best of the Performance GL1100 would be the 1983 bike .. comes with Factory HONDA RoadRace developed Anti-Dive TRAC front end - twin piston calipers etc . with an '80-'81 Close Ratio Transmission Gear Set installed.
The GL1200 is same swirl HEMI heads .. Torque Cams .. & a stroked crankshaft from 61.4 mm now 66mm .. kinda kick ass .. but which gets mugged by it's transmission gear set.
The GL1200 gear set require judicious throttle & clutch work to launch .. then wait for next gear .. and wait .. it's a lumbering Barge gear ratio set .
4cyl Goldwings are interesting .. strip off the Touring Bags & Fairing .. take 'em back to their '75-'76 high performance config. .. great low CG peg scraper .
