We are all familiar with compression ratios, but I wonder if there is a relationshipto cylinder pressure, psi. General specsusually calls out an acceptable minimum compression measurementsprobably for service limits and acceptable ring blow by.
But, if a compression ratio is a constant, then why wouldthe pressure not be the same for all engines with the same compression ratio?
Here are a some basic info.
Atmospheric Pressure = 14.7 psi (STP)
i.e. Compression Ratio = 10:1 (constant)
Intake Valve Close= 30 BBDC (air inertia and volumetric efficiency
irrelevant at cranking speed)
PV=nRT (carnot - ottocycle)
I can see how temperature may affect pressure (like a diesel ignition), but I would like to discard heat-transfer lossdue toshort time intervaleven though the speed is slow.
Need for someone to do their thermodynamics's homework.
To me, the compression check psi numbers should be fairly standard, but are they?Why can't there be a psi table for8:1. 8.5:1, 9:1, 10:1, 12:1. Also, is there a"rule-of-thumb"?
