As some of you may have already read, I cut a brand new rear tire down last week..The mourning period has now passed as my new tire is supposed to arrive on Thursday. I did all of the work the last time myself, but there were timeswhen I did struggle... Last time, I didn't have access to a jack, so I used the center stand. I struggled with getting the bike raised high enough to easily maneuver the lower portion of the shocks in and out of their mounting brackets.. I thought I'd solved the problem by putting small pieces of 2x4's underneath the center stand legs..but when I started attempting to raise the swing arm, I inadvertently pushed the bike off of the center stand, causing the bike to fall....I'm so stupid, I actually pushed it off TWO TIMES!!!I think I've got this part figured out, as I saw somewhere on this forum where someone had used cargo straps to secure the center stand to the crash bars, thus preventing the stand from retracting......but I'm not particularly crazy about the blocks of wood under the center stand... it just doesn't feel very stable.....
I now have access to a floor jack. Not a motorcycle jack, but a floor jack and I'm wondering if this will be of any help.Isthere a method to safelyraise the bike using a standard floor jack. Also, I don't have a trailer hitch on the bike ( I don't know if that matters).. And finally, is there an easy easy way to raise and lower the swing arm once the tire has been reinstalled? The last time, I just laid on the ground and tried to manhandle the tire/swing arm.. Is there a trick to this that I have not yet learned?
This may be a redundant post, but I couldn't find this exact information anywhere on the forum.. And as always, thanks to all that are kind enough to take the time to help an ignorant idiot like myself.
Best Regards,
Chester Gunn/Chula, GA
Best Regards,
