1 - 20 of 22 Posts
Thanks.
Ok, so what's the question? Not mind readers here.
On the 79, the "on/off" switch is most likely for the headlight.
Thanks, Jackhammer.
Discussion Starter · #8 ·
BigWingD wrote:
I dont know my 79 dont have it
I will check it when I install headlight, when I bought my bike headlight was missing. $50 is good price even w/o headlight!!!
Old Broad
Micheal, read the topic heading for the question.:shock::shock::shock::cooldevil::cooldevil::cooldevil::cooldevil::cooldevil::cooldevil::action::action::action:
Micheal, are you mixing your meds again. Blue ones in the morning and green one at night.:cheeky1:
Turn it on and see what happens with the motor off. It might be a fan switch.
Hobie
Most early model Honda motorcycles had a weak starting and charging system, so to combat the drain on the battery while starting, they were equipped with a handlebar switch that included an "on/off" switch for the headlight. Turn switch off, start bike, turn switch on to power headlight. This feature was also useful for the times when a low battery condition required an emergency trip home or to the shop; ride with headlight off in order to conserve power.
That makes sense to me. My '79 had a switch next to the neutral light that was used to by-pass a bad thermo switch for the fan. I put in a good thermo switch.;)
Regards,
Hobie
My 1975 BC 750K has an on/off switch in the same location and is for the headlight. Mine has since been wired to be on all the time required by law. At the time these bikes were made in the 70's, there was not a mandatory requirement to have the light on in the day time. You can just tell people the switch is for the passenger airbag.....:dude:
Discussion Starter · #16 ·
That switch works like "run" switch on my bike. I have two similar working switches. It looks like some electrical wizard was working hard on my bike, hanging wires, disconnected connectors, fan works when it feels like it. It is going to be a lot of fun!
1987 GL1200 Interstate
Keep tracing those wires...maybe the previous owner installed a "flux capacitor".
No, I think my VA doctor is though. He keeps changing what I take and how much I take versus what I'm used to.:shock::shock::shock::shock:
Besides, the title isn't the place to contain the whole question without at least some detailed information. Vague information gets vague answers.:waving::waving::waving:
It should be your headlight on/off switch. Honda didn't remove that switch till the 1980 model when it became mandatory on all bike in North America.
James
Sounds like someone replaced that switch unit with one from an older bike. My 76 had no off switch for the headlight. It probably does nothing.
1 - 20 of 22 Posts
