was out pluging wires back in as i took radio out to send to sierra.thought what the he$$.i would take farring off and looks like a plate around fan.the reason for this is po wired toggle switch in.now this is were i am stuck.the wires coming out of the fan are blue&black with a square plug. that he hot wired in for the fan.i see thermo switch plug it has two wires comeing out green&black it goes behind the plate that bolts to motor. the wires from thermo switch looks like they feed into wireing harnes donot see any cut wires or loose plug were fan plugs into.about ready to put everthing back together and just use toggle switch works fine that way.but would like it to kick on like it should.and still have toggle switch.hope i didnot ramble on to much:?:?:?:?
