A few weeks ago I bought this old S10 http://www.goldwingfacts.com/forums/4-miscellaneous-forum/636442-look-what-i-bought-today.html
Been working on it ever since a little at a time and just about have it in tip top shape. Was working on the AC, put a new compressor, accumulator and orifice tube in it and a new pressure switch. As many of you probably know the compressor cycles off the pressure switch, what was happening is after a little while it would start cycling real fast, clack clack clack every 1/2 second, figured it was the pressure switch so I changed it, same thing. The pressure gets down to about 25psi, it shuts off and about 26psi it comes back on, should come back on about 40psi. The bright idea I had was use something different. I had an old refrigerator out back so I too the temperature control out of it, drilled a small hole in the evap housing and ran the probe in it, connected it to the pressure switch wires and WALA it works perfect. I also took off the belt driven fan and put on an electric fan with a thermostatic control and tied it to the AC with a relay so it runs when the compressor is on also. I now have more in the little truck than it's worth but so it goes.
sounds like a fun little truck to have around when you are just poking around the block.
what kind of MPG do you anticipate it might give you around town?
As small as his town is John hard to figure MPG!
Drove it up to my Mom's tuesday, got 25.
that's not too bad, so it should give you 18ish or better all the time and most likely a lot better than the big truck.
I would hope so, my full size would do that when it was a little younger.
