I did some more of my winter maintenance today - I installed my new CB tuner, hooked up my SWR meter and tuned the antenna. I then replaced the clutch and choke cables. The choke cable was binding and needed to be replaced. I have been wanting to replace the clutch cable for a while, as I didn't know how old it is, and really could do without it breaking on me long from home. I figured if I'm doing those, I might as well do the throttle cables as well, so I ordered all four.
So I did the clutch and choke cables without much problem. Then I had a look at the throttle cables. I can see easily enough where they route to, but unlike the clutch, there's no obvious way that they fasten at either end. I can tell it's going to be a PITA to get the carb end of the throttle cables off, and as for the handlebar end - I don't even see how they fasten.
I had a look through the Honda, Haynes and Clymer service manuals, and unless I'm missing it in all three, I didn't find any mention of replacing throttle cables other than to "replace them if kinked or worn."
So...is there something simple I'm missing? Is there a simple procedure, or should I just do my usual routine of taking stuff apart and figuring it out as I go along?
I've been thinking for a while about braided braine lines. Now that I have the bike ripped apart, it's obvious that it would be advantageous to replace brake lines with braided lines NOW, rather than waiting to do it later, and having to tear it all apart again. I know my GSXR had braided lines, and the brakes were ROCK SOLID, and felt like you threw an anchor out when you grabbed some brake - but they had to be on that bike. Is there enough of a difference on the Goldwing to make it worthwhile, or should I spend the couple hundred dollars elsewhere?
Oh...and my wife hasn't noticed the pile of motorcycle parts growing in our dining room...either that, or she has decided not to say anything. Yet.
