I AM TRYING TO REMOVE THE CARBURATOR UNIT FROM MY 1982 GOLDWING GL1100 AS ONE PIECE. I HAVE IT ALL DISCONNECTED EXCEPT FOR THE THROTTLE CABLES.I AM NOT SURE WHAT TO UNHOOK FOR THIS.CAN ANY ONE HELP? THANKS BUDDYBOY!!!!
The 10mm nuts holding them on have to be loosened. you will also probalby need to pry the lug open a bit for the threaded part to clear it.
Hi buddyboy. Mine a GL1100 as well and I had to pry open the tab as well. My n#main problem tough was getting at the screw holding the choke cable in place.
