Does anyone know what parts or jets of the carb does the throttle activate, control or move. When I say circuit, I do not mean electrical circuit I mean mechincal circuit.
Banned
Here is a GL1000 carb. Close enough.
The only thing that actually moves when you open the throttle, other than the throttle plate, is the slide which raises the main jet needle. I found a good test to see if they are moving like they should. My shop vac nozzle fits perfectly in the intake runner so I shove it in there and while looking in the inside of the plenum and the slide will move up and down as you open and close the throttle. Change the vac to the next carb and check it etc.
This is a picture of the GL1200I Carb that I have. Please identify the parts that you had in you response to my topic from the ones on this oicture. Thanks DWG
Banned
3 through 7, ....and 37.
