Like everybody's already said, it's not normal.
If there's no flip lever on your grip for you to release(the poorman's locking cruisecontrol), then try to adjust the tension at the throttle cables by the grips or carbs, or you could try adjusting the tension by the adjustor that's hidden on the leftside of the airbox (it'll be one of the cables by the spark plug wires) and you'll need to peel back the insulator on the throttle cable to see the nut.
I wouldstart at the throttle cable nuts on the bottom of your handlebar but don't just loosen and tighten haphazardly, think clearly about which one you're tightening/loosening. If that doesn't do it, then move on to trying the adjustor nut next to the airbox cover's leftside, and then if that doesn't correct the tension, try to reach behind the carbs and adjust the tension on the only throttle cable that has the adjustor nut (can't remember if the one with the adjustor nut at the carb is the pull or push one right now, and you'd need a 10mm crowsfoot plus a 10mm wrench to do it).
Good luck and congrats on your purchase.
