1 - 15 of 15 Posts
Would you happen to know if the ticking sound i hear coming from the engine
is normal. It almost sounds like loose plug wires on a car when the silicone
is shot and the spark jumps to ground. Thanks
And what perchance is the motor you are speaking of?
Actually, it would help to know what you are talking about. Be it a 1000, 1100, 1200, 1500, or the 1800.A few more details might help the Gurus delve into the problem.
If you have an 831100 Interstate like myself, a little ticking is acceptable.Itsjustthevalve assembly doing it's job.
If it's really rattling, then a valve adjustment might be in order.
Hobie
The odd ticking or rattling sound from these engines, especially the 4 cylinder, isn't unusual. Primary chain rattle, and valve train noise is pretty common. Bangs and knocks aren't. Hobie has it right. If the noise seems to go away when you get into gear it's probably the primary chain, if it stays it's probably from the valves. If you are describing a sharp snapping sound, that isn't a normal sound. Kinda hard to be very specific from the description.
How many miles on this puppy?:baffled:
cmeador, that would depend on where the ticking noise is coming from.. If from the R/H cylinder head area then a lot of early Wings do that. If from other places then it would depend on where it is coming from & how loud, & how often.
In order for us to give you good feed-back here we really need for you to explain where the noise is coming from, whether hot or cold, the engine RPM it happens at, & any other particulars. It's very hard to diagnose an engine noise over the Internet without a very precise explanation on your part.
Twisty
Hi cmeadorand welcome to the forum. Valve ticking is almost always audible on the GL1100, even when the valves are properly adjusted. If the sound is more electrical, then you might have a bad plug cap or lead. Spraying WD40 onto the cap or leads will usually make the noise go away for a few minutes and that's the way to test.
I just adjusted my valves, again. Did them nice and snug, and locked 'em down, all to spec. There was audible ticking on the left side, which has quieted down. Now the right is audible. I get the impression this is quite normal, especially on the 1-3 cylinder side for early wings? I may also be a little low in oil,  which could affect right?
It's when you don't hear anything with solid lifters you have to worry! A light ticking won't hurt anything.
Thanks, Paul. Man, this bike runs awesome now! It's just ticking/idling nicely, lots of power. It's still sputtering a little, and i think that's because i'm only partly into a 2nd tank after cleaning it out. Could still be moisture? I'm adding gasline treatment each time.
Who knows, ride it a bit and see if it goes away.
Find a pitch black place and start it up to see if your plug wires are arcing?
And check for a exhaust leak by the engine?
Just to eliminate those two things!
You can go nuts chasing noises on old bike, I learned to ignore them !:baffled:
readjusted valves on right side, added some oil, she purrs.
I'd rather hear a little ticking than nothing. At least you know that the valves are closing! Just me , though.
1 - 15 of 15 Posts
