I set them, the bike has not run on points since I've bought it, I may try the electro ignition that came with it if I don't have this started tomorrow. I did the gap n made sure when one point is open, the other is closed for each respective mark (#1 & #2). Still hasn't started, should I aim for dead on balls at the F line or in-between the F and TDC?
You can only check the advance with a timing light and the special window that replaces the plug. Marking the F mark with a black marker helps to see it.
So, then your Gold Wing was running fairly well just before you adjusted the points?
gumbyredd
Long story short, bought a lemon. It has electro ignition and said it was only a dead battery with a salvage title, wasn't in any condition to pass inspection, ghetto hard wired just to function, no charging system or lights. Paid a shop to rewire, I swapped back to points thinking that'd be easier, clearly wrong since it's not starting. Now I have lights and charging system (presumably charging system once it'll start). I'm trying to figure out why it's not starting, I've done what I've mentioned above, although upon inspection one float bowl was nasty nasty, but did have cleaner run thru everything seemingly with ease, so I think somehow my work on the points is incorrect. If somebody has a clear, distinct and precise direction on how this should be set up, that's be swell, since my backup transportation to work has also died. The service manual is a bit confusing on the matter
