The bike cranks over, but doesn't start currently because of the points being out of time and/or the carb bring clogged up. A carb rebuild kit is on the way but I'm trying to solve this issue first. I rotated the breaker plate clockwise and stopped both of the points opening on the #2 flywheel mark. Only one is supposed to be open at once correct?
Now hear me out: because I know the bike has run with the belt and internals as they are, apart from having the electro ignition that I also didn't feel like adding the extra cost from the shop the did the stock wiring (literally just plugged everything in and didn't route for 650$ or so) the timing advancer literally only goes on the cam end one way because of the keyway esq notch, so therefore why would the F mark not be where the highest point on the cam would be?
Kool,
You are stuck on one thought and blocking out what you need to hear most.
Forget about lining up the flywheel and advance and anything else. None of those things will keep it from running. They are used to tune the engine. What you need to do is understand how to adjust the point gap.
You have never been close to the right technique. It is a 2 step process for each cylinder.
I can't seem to find a real good picture but I found the best I could. Then I used my poor drawing to show what I wanted to illustrate.
What you need to know is that the points rub block rubs against a shaft that is not round but cam shaped. It has a bump or hill built in too it.
Look at your bike and find the top of the bump or hill. The highest point of the bump or hill must align with the rub block on the points. Rotate the engine until the rub point is aligned with the bump. (hill- cam) Once you have the rub block on top of the hill adjust that set of points.
Now you are half done as you need to do this to the other set. Turn the engine until the bump- hill align with the rub block 0n the other set of points. When the other set is aligned properly adjust the gap.
Regardless of the other adjustments you should be able to start the engine now.
Make sure you have the cover on the sight glass so you do not throw oil all over the place.
So in a nutshell. turn the engine until the rub block on the points is aligned with the highest point on the distributor cam. Then adjust/
Simple as that. Oh, don't forget to do it once for each set of point. The high points (hills) will not be near as defined as the picture.
The picture shows 4 cam lobes (bumps) You will only have one or two. I can't remember.
The black dot shows the rub block while the red dot shows the top of the cam lobe. The illustrations shows only one set of points where you will have to do the process twice. Once for each set of points.
