If you have all the wiring correct. That is both the primary and spark plug wires. If you have the point gap right. Regardless of anything else the bike should run or try very hard to run.The high points of the cam is how I've been adjusting the points since I've been trying this. I understand the concept of how to set gap but I don't understand why it won't start according to instruction.
Make sure the wires on the point set end up at the right coils..
Make sure the plug wires are on the correct spark plugs. That is the plug wires from the right coil go to the 2 front cylinders.
Left coil plug wires go to the rear 2 cylinders.
ALSO>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
The yellow wire has to go from the right coil to the left set of points
The blue wire has to go from the left coil to the right point set.
If you have the yellow and blue wires correct.
If you have the spark plugs placed correct.
If you have the points adjusted correct.
.If the rest of the bike is in good working order.
The engine should run or at least try to run.
If you get that far then talk about timing and tuning to get it just right. 🌝
