Howdy all,
The bike in question is an '83 interstate, with 56k miles. It was a well-maintained garage-kept machine; I'm the second owner. I just put on Goodyear timing belts, adjusted the valves, replaced plugs, and synched the carbs, and a myriad of service tasks. It starts great cold (like instantly with choke), and once warm, idles nicely, but SOMETIMES needs to crank for a second longer than I think it should when at "full hot". The issue is at low-end (under 2500 rpm). There is what sounds like a rough "shuddering" as it revs to above 2500. It SOUNDS like pre-detonation, and FWIW, I can get legitimate "ping" at 45-50 mph in OD if I roll 'em open hard. I did not think that was normal, and it sure doesn't make me happy. I'm running 87 from Chevron if it matters; it's also been 94-98f here in NE GA. It seems as though the advance rate is inconsistent, as there are a precious few times it doesn't ping at WOT/OD, and even starts hot w/o more than a few turns of the crank.
What are the odds of a sticking advancer? How hard is this to remedy?
Thanks!
Fabricator
Howdy all,
Thanks!
Fabricator
