Help !! I am in the process of changing timing belts and according to Clymers you must first set the crank to the T 1 line and then set the cam gears to both respective marks . Well I have the crank and left side cam gear aligned properly but I cannot get the right side cam gear to budge. I believe everything rotates clockwise when looking from the front of the bike. I have already broken the mounting bolt on the right side cam gear and fortunately gotten it out with an easy out but how do I get that right side cam gear to move to it's proper alignment. Thanks
