Are there any physical differences between the GL1500 belt tensioners and the GL1100 belt tensioners (adjusters). I see plenty of inexpensive tensioners on E-Bay for the 1100 that appear the same as the 1500's.
Respectfully
Michael
As I read through it, it looks like the only difference between the 1100 and the 1500 tensioners is the backing plate. hope this helps.
Thanks Big E, I did not see that when I searched the forums. Good catch.:waving:
Michael
Michael: I have a set of used tensioners from my 1990 GL1500 if you need them. I just replaced both at 60K miles. No rough bearings or noise -- just a peace-of-mind swap, and I'm way too old to wear out these new ones... Yours for the shipping if you can use them.
