was wondering what would cause this. i triple checked everything, turned the engine by hand, no problems, the cam pulley marks were facing "up", the crank marks were in alignment with the cam pulleys, the ignition pulsers were reinstalled in the exact positions.
the idle seems to lope, but steady, and is harder to start
maybe the timing is 180 degrees off?
My timing was 180 deg off on one side when I bought my bike. It was hard to start but it ran. It had NO low end power but ran like a scalded dog above 4000 rpms. It didnt lope, kinda ran smooth but not as smooth as it runs now. My left cam the words on the pulley were up and the right cam pulley the words were upside down. When I pulled off the belt the right cam spun around about 150 deg. I made sure that the crank was between 1-2 and 3-4 marks so there wasnt any pistons on TDC. Also when the cams are in time with each other, both of the keyways in the cam will face the same way. IIRC I had to remove the center bolt and washer from both cams to see the keyway.
Other side of the pond
If all the timing marks are aligned and the UP is reading right way up, you can't be out 180 degrees. If you are, one of the UP marks is upside down at the mark on the engine casing.
Basically if your marks are aligned as in these pictures here, you got it right. In that case you should check for vacuum leaks or bad plug leads or caps.
timing belts, what went wrong
i was pulling the spark plugs to recheck my timing marks. found some debris bridging one of the spark plug electrodes
cleaned it off and reinstalled the spark plugs, fired right up and idled smoothly the way it should.
happy!!:claps::bow:
Vern
Please keep it to one tread per topic. This makes it three on the same subject. Clutters up the forum and doesn't help others looking for answers that might happen across through a search, the answer needs to stay with the question.
I am glad you found the problem,
a moderator may merge the threads.
Discussion Starter · #9 ·
go ahead and merge this. thanks to the support of you guys i was able to regain the confidence to do this:waving:
