Well, Forum, you have given me a whole lot of good advice as I enter the wonderful world of Goldwing. Thanks to all those who have helped - - -
My first Wing, pictured, after a whole lot of trying to figure it out, suffers from 'stator disease'. The new stator is in, and I figure as long as I have it torn apart, I might as well see how many things I can fix while I am 'in there'. Ripping out the terrible job of putting electricity to the sidecar is one job.
At first I couldn't figure out why I was able to drive 1,300 miles with a bad stator, and that made it difficult to conclude that the stator was, indeed, bad. Just for the record, based on my (admittedly) limited experience, the bikeseems to charge just fine with only 2 phases of the 3 phase alternator working. The other two, however, will overheat and cause intermittant shut-downs, until one of them also fails - - either by opening, or overheating a connection. Then you have exactly zero charge reaching the battery, and it will run until the battery gets too low, and then it will leave you walking.
I have pulled all the paintable surfaces - - - luggage compartments, tank cover, and fairing sub-panels. The fairing itself, even with the manual, is not an easy thing to remove.
I have checked brake pads (near new) calipers (10mm each) plan to change oil and coolant. Will also check the on-board compressor, have new fork seals, will put on a new rear tire - - - . What else? I also got a pair of new timing belts, and will get to them when I have the fairing and radiator pulled. So - - My question for you is this - - - -
Why do I have to line-up the timing marks to change the belts? I know, I know - - - they DO have to line-up, but it ran so well (when it ran) I am reluctant to mess with it. If I don't move anything when I remove the old belts, and put in the new ones, then it should line up just fine - - No? Or maybe it isn't as hard as I think to get the timing marks lined up - - With no battery or charging system, I can't 'bump' it to TDC. So do you do that manually, by getting a wrench on the drive-train, somehwere, and wrenching it into position?
Yeah, yeah. That has to be a 'newby' question, but I AM a newby, so a little patience, brother. 'Just line-up the marks, do it form there, and quit your whining' is a perfectly reasonable answer. 'Mark where you started and make sure that is where you are when you are done' will also work.
Thanks, Regards, Good riding.
CorpusKid
CorpusKid
