As far as belt changing video's I haven't seen any.. However I'd check YouTube to see what is there and also a member might come along with a link.. It's not that hard to do with just the shop manual as that's what I used.. I recommend the Clymer..
The charging system is the only real weakness on a 1200 especially the Fuelie's due to the larger, 500 watt, charging system and the connectors are the weak link on that due to heat and age.. First, what does the voltmeter read that's on the right hand side? It should read about 14-14.2vdc. You can check the battery voltage also which will be a bit higher at about 14-14.3vdc..
Next take a look at the charging system connectors. There are 4 to look at for signs of getting hot and burning: the Stator connector located to the left of the battery accessible by removing the side cover. Next is the 2 regulator/rectifier connectors. To access these you'll have to remove the fake tank fairing and it's on the center left kinda buried a bit.. The manual can walk you through removing the tank fairing also.. The 4th connector is on the starter solenoid and has 4 wires. The 2 in the rear of the connector are the hot wire and the ground for energizing the solenoid for starting.. The 2 red-red/white wires in the front of the connector are the ones that will cause problems as they carry most of the amperage load for the system and will burn!!
I have the same bike and I had problems starting with the stator connector burning. I wound up removing all 4 connectors, soldering/heat shrink insulating 3 new 12 guage yellow wires at the stator and doing the same with the regulator/rectifier wires. At the starter solenoid I clipped the red-red/white wires and soldered them to a 30 amp inline fuse holder, bypassing the 30amp dogbone fuse, and crimping/soldering a round end connector for connection to the hot side of the solenoid...
That outta get you started... Anymore questions just ask and we'll try to help out!!
Oh... I almost forgot... Here's a parts list you might find usefull! The fuel pumps/filters are for the carb's 1200's as are a few other things but timing belts, hoses and such are good numbers!
Good Luck with her!!
GL1200 Goldwing Parts List
Oil Filters
Amsoil – SMF-101
Purolator – ML16809
Fram – CH6009
STP – SMO-09
K&N – KN401
WIX - 24940
NAPA – NAPA Gold 4940
Air Filter
K&N HA-8084
Radiator Cap
NAPA – 703-1443 rad cap: NAPA part no. 31333 $18.69
Stant – 10227 Stant GL1200 radiator cap is now 31333 rather than 10227. 07/03/27
Honda part no. 19045-MB0-013 $39.60
Thermostat (180 degree)
NAPA – 535080 possible new part number 33488
Stant – 45868
AutoZone – 15868
Honda Part No.19300-MG9-000
Radiator Hose: (Cut in half to make 2 hoses)
NAPA – 7733 (one piece; needs to be cut)
Gates – 21008
CarQuest - 21029 (made by Gates)
Gates 21488
Radiator hose - Dayco P/N: B70834
Sold at Advanced Auto Parts.
Honda Part No. 19501-431-000 (upper) Honda Part No.19502-MG9-000 (lower)
Spark Plugs
AC Delco - ACR121XLS
NGK Standard plug – DPR8EA-9 (gap .035)
NGK Iridium plug – DPR8EIX-9 (gap .035)
Fuel Filter
Napa 3011
Possible fuel pumps replacement, might need a little accommodating
1 85 Honda Prelude fuel pump
2 Airtex e8316 ( bought at Advanced)
3 Fuel Pump NAPA
Part Number: BK 6101051
Product Line: Balkamp
Attributes:
Fuel Pump Fitting Size : NPTF 1/8-27 Int.
Fuel Pump Fitting Type : NPTF 1/8-27 Int.
Fuel Pump Gallons Per Hour : 34 gph
Fuel Pump Pressure Rating : 3 - 4.5 psi
Manufacturer : Facet
Manufacturer Part Number : 40180
Warranty: 12 Months
About $54 in US
Timing Belts (2 each)
NAPA – 250070
Gates – 5043 or T070 (available thru most NAPA & CarQuest stores)
Goodyear - 40272
Dayco 95070
Battery (Gel Cell)
Deka PowerSport Gel – ETX18L (NAPA)
Odyssey Gel – PC680 or PC680MJ
YUASA - “YTX24HL-BS”, “Y50-N18L-A-CX”, “Y50-N18L-A”
WESTCO – 12V22 Sealed AGM
