Nope, sure haven’t? Sounds like another “Ford” recall is in the future? 🤣Have you seen the "wet" belts fitted to some Fords now!
How would you explain why Honda does put a replacement interval on Honda cars?
I doubt if you would ever find any vehicle that uses timing belts that requires the engine to be dismantled. Cars engines with belts can be replaced without pulling the engine. Part of normal maintenance.
Most certainly is. “When I doubt, change them out.”I owned a 80's something year Ford Escort for a few years. It has a timing belt and interference engine. Did not have it long enough to have any major problems. But, while working the counter at a auto parts store in town, I did have a customer come in that had broken the belt somehow driving. He swore up and down he did not need to pull the head and check the valves and all "cause he was not going fast?" Well, after all the bs was done and he replaced the belt, he had to tear down the engine and replace several bent valves!! I bought a 99 GL1500 a few years ago and changed the belts just to be on the safe side! Easy for me as I have done several before on other bikes. Cheap insurance I think.
Because of the way people post, it is difficult to search for timing belt failures, but in following this and one other GoldWing forum, I know I have seen half a dozen over the last few years.
I've probably changed hundreds on all kinds of engines, and have seen a ton of failures. Typically an engine that runs everyday and is maintained will see a long belt life, and even some warning when the belt starts to get old. However, engines that sit, keep the tight curve around the crank sprocket in the same place, and the belt will typically fail there. You can even see it in the broken belt that it has taken a permanent set in that place. Unfortunately many GoldWings can often sit for decades. I didn't do a lot of research before purchase but got lucky and ended up with a daily driver. Sure the mileage was high, but it runs like a Swiss watch. Over and over I see folks here with "barn finds" with super low milage and good looks, but man the problems they have trying to resurrect them.
They are larger belts so load is not an issue, what conditions are different? It tells me they don't expect a goldwing to still be on the road that long.Most likely due to the load of the belt and condition it is run in requires it. The fact that there is a service interval on a car and not on the motorcycle is very telling.
My wife had an ‘86 Escort. The belt broke on us in Vermont. Rural, rural, did I mention rural Vermont? Somehow we managed not to do any damage to the engine. The mechanic was both shocked and disappointed that we didn’t do damage!I owned a 80's something year Ford Escort for a few years. It has a timing belt and interference engine. Did not have it long enough to have any major problems. But, while working the counter at a auto parts store in town, I did have a customer come in that had broken the belt somehow driving. He swore up and down he did not need to pull the head and check the valves and all "cause he was not going fast?" Well, after all the bs was done and he replaced the belt, he had to tear down the engine and replace several bent valves!! I bought a 99 GL1500 a few years ago and changed the belts just to be on the safe side! Easy for me as I have done several before on other bikes. Cheap insurance I think.
It tells me that Honda knows that in this particular design, they don't usually fail and only need inspected every 100,000 miles . You don't have to believe me, believe Honda engineers.They are larger belts so load is not an issue, what conditions are different? It tells me they don't expect a goldwing to still be on the road that long.
One question, if the belt system was so bulletproof, why did Honda change it to timing chains on the 1800's?It tells me that Honda knows that in this particular design, they don't usually fail and only need inspected every 100,000 miles . You don't have to believe me, believe Honda engineers.
The biggest condition of all.................. It is a different design. A honda car motor is not a honda motorcycle motor. Also each motor type is of different design. So what may need to be done on a 2.5 doesn't need done on a 3.0. Every motor has its weakness (some motors it's the timing belt(ford escorts were known for breaking belts).
If gl1500's were breaking belts and killing people (no matter how old the motors are), in the USA there would be lawyers suing and information would be out there. It would be all over the internet.
For example the GM ignition lock issue. GM is doing recalls on cars that are almost 20 years old due to safety.
I have seen people say that it's cheap insurance. That is a very good thing to compare it too. Cheap insurance is usually worthless (that's is why its cheap, it doesn't pay).
You go ahead and do as you wish. If it were mine I would change them. For $50 and a couple hours the peace of mind is easily worth it.It tells me that Honda knows that in this particular design, they don't usually fail and only need inspected every 100,000 miles . You don't have to believe me, believe Honda engineers.
I imagine it is improvement on design. Another way to put it, if the belts were so bad, why did they use them from 1976 to 2000.One question, if the belt system was so bulletproof, why did Honda change it to timing chains on the 1800's?
To each there own, whatever makes each person happy.You go ahead and do as you wish. If it were mine I would change them. For $50 and a couple hours the peace of mind is easily worth it.
