please help. does anyone know if ect timing mod for valkerie will work the same on gl1500.
i know you can change trigger wheel. thought is ect mod. would work on gl1500 that would be much easy to do.
will that modification work on gl1500 also.
Old School Guru
A couple of things to consider, the Valk uses different cam profiles and six carbs. I don't believe that using the Valk's ECM would work properly on the GL1500. The timing mods for the Valk are designed for the Valk's cams and carb setup, which is a lot different from the Wing's. Also, on the Valk, you have differnt heads, different exhaust, different rear gearing, (although I think the transmission is the same). Too many little differences make a big difference on how a engine in a particular application performs.I doubt that mods that would allow a Valk's 1500 engine to perform better would have the same results on the Wing's 1500 engine, unless they were designed for the Wing.:)
Gene:waving:
But, one thing to consider it the trigger.
Many attempt to change the timing wheel 4 vs 6 degree. They say to stay away from the 6 degree trigger for a Goldwing. Both wheels would just be an attempt to change timing.
I assume the mod using a ECT would be not to change the timing wheel. Manual and variable control. The question would be does the Goldwing ECM have the input for a ECT anddoes it work similar to a Valk.
Many folks us the trigger wheel for a hesitation problem for the Goldwing which I believe is carburation related, IMO. I do not know if the wheels are used for performance (power). Do the Valk guys use the triggers for the same reason?
I have a96 gl1500 se I wasn`t concerned with hessitation it was fuel economy so I did a 4 degree trigger wheel & extractor kit with no mpg increase all I got was better take-off ! I also have the k&n air filter !Craig
