Hello all..
What do ya'll think of a TIR3 light installed where the rear reflector mounts and tied into the brake light? I saw this once and it worked perfect...low enough not to blind anyone (that i could tell) Saw this done, and it fits almost perfectly in the reflector position. He removed the reflector, fed the wires through the screw hole and used the two self tapping screws to secure it..lokks like it was made for the goldwing. Simple ground and hot wire into brake light in rear. He set the flash to standard flash pattern and looks just like any other flash pattern on other units. Only thing different is that it continues to flash as long as brakes are applied. I have not seen anything in regards to this being illegal in any code information. Thoughts?
Hello all..
