1 - 9 of 9 Posts
This seems technical and MC related because sometimes we need to change tires w/o the aid of a high capacity air compressor.
I watched several youtube videos whereby people used rapidly heated air to get the tire to seal against the rim. Really rather exciting.
I have not done this but I damn sure am going to try it because it looks like a lot of fun and could be a useful skill.
Question 1: Do yall have any experience with this inflation method? Tips? Tricks?
Question 2: What accelerant should I use? I current have carb cleaner (which burns well but more controlled than gasoline), gasoline and ether (starting fluid) which seems to be even more violent than gasoline.
big PIA
I have done it with starting fluid on semi tire and car tires, have never changed a bike tire yet, getting ready to order tires and change them myself by hand.
I know with starting fluid it does not take much, be very sparing with it
I have done this as well but on a set of steel rims. ( yes rims use to be steel) ...lol never tried it in aluminum rims
Use VERY VERY sparingly! There is not a huge air volume to a MC tire and when lit, those gases create a very large volume increase!
Seen it done with starter fluid on a large truck tire and he didn't use very much. It actually jumped into the air enough to almost flip over. That was a BIG heavy tire too.
Not sure I would try it. Please video and post it if you go.
Tim
I've done that several times but the last time I tried it the starting fluid wasn't volatile enough to do the job, it would just burn. Never needed any help on motorcycle tires, just large tires that have a big gap between the bead and rim.
Good luck, sounds dangerous to me. We have a shop her Temecula Motor Sports that will mount and balance the tire off the bike for $15.00 . You might try a few shops near you to see what they charge with the wheel off the bike.
1984 GL1200 Interstate
I've done it on garden tractor tires and wheelbarrow tires and it's fun, but it's a lot safer to wrap a ratcheting tie down strap around the circumference of the tire and tighten it until the bead makes good enough contact with the wheel rim and then airing it up. I know, I'm such a buzz kill.
CrabbyJack
1 - 9 of 9 Posts
