I bought a 95 SE last summer.
Needed a new rear tire and my mechanic couldnt find out if the tire needed a higher pressure due to the Landing Gear on the bike.
Found the info concerning the Louisiana company that was wiped out due to Katrina.
Any help will be greatly appreciated
John H.
Augusta Maine
Oh - THAT guy...
Landing gear? Does it fly?
If this is an add-on wheel thing, then the rear pressure would need increased a bit just due to loading more than likely, like to a pressure you might use riding two-up, but stay within a pound or two of max cold sidewall indicated pressure, measured when cold.
This goldwing of your's sounds like my old one. Can I ask you what color it is? Anyway, when I had one and I installed landing gear, I increased the pressure by 2 pounds as that what the owners manual said to do. I never had a problem with it when it was inflated that way. When I traded the bike in, I had about 5,000 miles on it with the landing gear installed. Hope this helps. Is the bike that purple color they made in 95? Sure would like to know what happened to that bike........ Randy
Oh - THAT guy...
Can you post a pic? Curious...
