1 - 15 of 15 Posts
going to install a set of new tires on my 1800 what tires should i be looking at for higher mileage? and should i use dyna beads/ THANKS FOR THE INPUT
E-3 on the front and Michelin Primacy Alpin PA3 ZP on the rear. Put dyna beads in both front and rear and inflate with nitrogen to rated tire PIS. Inatalled this combo on my ride in the spring and have had 0 tire problems since.
Have a Dunlop E3 on front and a Metzeler 880 rear on my 1800... they work good... next tires are going to be Dunlop E3s front and rear becuse of what I've read on this forum ..Dynabeads ...yes
Very active member
You're gonna get mixed review on beads. I know from previous threads that there are many different opinions. Some people think they are worthless and the sheer physics of them are not even plausible. Good luck. I disagree on the needs but your preference. I have heard a lot of good things about the metzlers
My new to me GL1500A came with new E3's really like the tire for all around riding...as for the dynabeads I run them in my VTX with zero problems, just havent gotten around to the GL yet...good luck on your choice....
Ya, but I bought a 95 with 7 year old tires, weights on wheels, and normal compressor air, 10K miles this year and no problems either LOL
I used Dyna beads for 10k on the 88 and no problems either and just put those tire on the 95 awhile back with same beads and no problems, using compressor air still.
Nitrogen is a bunch of hype only when it comes to normal road use tires.
At Indy 500 with near 200mph speeds for hours at a time it may help the race cars, normal road use it's nothing but hype!
I ran Dynabeads for a few years with no noticeable side effects until last year. On my ZZR600 I picked up a bad vibration at 75 MPH. I never got the chance to remove the beads and static balance as I wrecked the bike on that trip. Then, the next bike I bought was a VFR with Dynabeads from previous owner. When I changed tires I noticed the dynabeads chewed up the inside of the tires pretty good.
These two incidents are far from scientific and I had several other acceptable results so I dont know what to say other than I now stick to static balancing as I do my own at home and enjoy the challenge of getting the tire perfect. Does one work better than another? Who knows?
Craig
Being budget minded, I just installed a new Kenda on the front...very pleased with it. By reputation, it should give good service.
Goldwing Addict :-)
Exavid told me he runs 78% nitrogen in his tires, so that's what I'm doing too. I have my compressor setup that way. :D
Oh - THAT guy...
Now that's funny! Wonder how many people will get it?
Agree though - Nitrogen is great for extreme conditions, but an unnecessary cost in a street rig. As soon as you need to adjust pressure for any reason you lose the benefit by adding 'mixed' air. Nothing beats doing good PM/inspections frequently.
I still have the Dunlop E3 tires that came with the bike when I bought it. They are getting to the point where I'm going to change them soon.
Not sure about beads or weights. I'll decide when I do the tires.
I'm running 100% air in mine. There may be just a tad of moisture too. Throw in a bit of compressor oil also.
My corner gas station charges 50 cents to self fill your tires with 78% Nitrogen!!
BigWorm has a vary good tire combination, however I run the Bridgestone G709 on the front. Beeds also. No more cupping and no internal tire wear.
Corventure Dave
Just put a new E3 on front of my bike yesterday, works and sounds great without that bubble!
Goldwing Addict :-)
I imagine quite a few here would get it. We've got a lot of smart people on this forum. :cheesygrin:
Discussion Starter · #15 ·
i work in a car dealership as a subaru tech and we use nitrogen which is 96% pure,anything under 80% is just pure air as air already has 72-79% nitrogen in it, but using nitrogen takes awhile for the tires to warm up. not a good thing for a bike on cold days.
1 - 15 of 15 Posts
