Too light rated tire?
1365 Views 23 Replies 15 Participants Last post by  cyclewizard
I was doing some research today to figure out what to replace my rear tire with and noticed that my front tire, a new looking (PO said it was new when I bought the bike in January and it does look new) D404 Dunlop, is only rated at 639 lbs. I have the full fairing and ride 2 up occasionally. Plus I am no small fry at 235. Is this enough tire or should I replace the front tire too?
1 - 20 of 24 Posts
Both my 1100's had the 404's on them. I had no problems with them on the weight, I suspect the rear would be more the one that would be concening on that.
My CB 750 has 404's on it, no problem. My 1200 never will after seeing my buddy's 1100 blow the side walls on a new 404 on the rear. Presure and all was correct. You might be ok on the front but I have always put a better rated tire than what I need. Just play it safe.
The stock front tire for an 1800 is rated at 600 lbs. (272kg).
I run the D404's on my 1100 with no problems.
I ran a 404 on the rear of my 1200 and only got around 3k.
I ordered an Elite 3 for the rear. If the profiles work together I think I will just stick with the combo. If not, then I will get the Elite 3 for the front.
On a related note, the dealer is getting me the Elite 3 for $140 plus $15 for mounting and balancing. With shipping, that was less than I could find it on the internet and it would have been about $40 to get it mounted.
Wow, 3,000 miles? That would suck.
I'm new to this. What kind of mileage is normal for tires on our bikes?
I just had a new set of Kendas mounted.
i use d404 on both wheels, never had a problem either on my 1100 or my 1200, the last one i changed had 6.000 kilometres on the rear and the front one is still on it
I tried a 404 dunlop on my 1100 a couple years ago because all the others were on backorder, and the 404 would swell up when it gets hot and rub the torque bar that goes between the rear brake caliber and the frame, as for the front I had one of those to, the front 404 has such a soft sidewall I would compare it to an intertube, if it was somehow punctured and lost air it would most definetly go to the rim and cause a crash, stick to something with a stiff sidewall like the elite II's or elite III's, metzlers are tough tires but wear unevenly and get rough, never tried bridgestones might look into them also, hope this helps. I like a tire that will hold the bike up if it loses air, gives you a little insurance cause those roofing nails can be picked up anywhere.
Hey Andy,
I'm a big fan of buying locally too. Especially tires because if you have a problem you know who to call, and you won't have additional mounting fees to replace the tire. And like you I've found that some places can be competitive, price wise.
I think the biggest plus, though, is the goodwill you build. It will pay off some day.
I found out recently that my local dealer was doing a poor job on my tires. I mounted the last set myself and found that the splines on the rear hub had apparently never been greased as they should when replacing tires. I am leaning more and more to never letting anyone else touch my bike, that way I know what was done and I know the condition of the parts.
I plan to pull the wheel and just deliver the rim to the dealer. I will regrease the splines myself.
I agree, you should never trust a dealer to do a job right. I always pull the rims myself and take the wheels in to have the tires mounted and balanced.
But remember, if you are putting 5k miles per year on your bike and getting 15k out of a set of tires, that's too long between spline lubes and you should be pulling the wheel for lubing at least once in the interim. Maybe twice depending on climate & conditions.
all depends on HOW you ride.... I have over 25K on my HD dunlops
I put over 10,000 miles a year on my bike and rarely go a year between tire changes. The tires I just took off were put on in March but I had a nail incident that dictated replacement. The splines were dusty and dry.
Hi Tracker,
I just caught the (I presume) 6,000 km on the tire. Correct me if I'm wrong, but that's around 4,200 miles. That's very poor mileage in my estimation.
And Gary,
I didn't mean toimply that you were not maintaining your bike correctly, and thenumbers I threw out were merely as an example.
It was in no way meant as a personal attack. I sincerely apologize if I led you to believe otherwise.
I once got about 3000 on a cheng-sing (cheap s***) on my 1000 that also had a hack at the time.... but that is lousy milage.
the 404's aren't known for being great tires. Unfortunately the really early wings have 17" rears and dunlop did not carry the 17" tire over to the E-IIIs
And Gary,
Dennis, I didn't take it as an attack.My reply was meantto clarify that it was definitely a situation where the dealer should have taken care of something in the course of another service and didn't. Just kind of a reminder that dealers aren't perfect. If you find a good one that you trust, treasure them.
. Ive ran the 404s on otherbikes and never got good mileage out of the rears, .that load rating should be OK for the front.I prefer Metzlers, but thats not in my budget today. I just got in a Kenda Kruz rear for my 83 Aspencade. It is rated at 908 lbs. It appears to be a stout tire with a stiff sidewall. I have never ran them before. 81 dollars delivered. Time will tell. JB
1 - 20 of 24 Posts
