besides some small funnels, small enough to fit in the fuel line, what else do I need to do this job? I will be using the Yamaha carb cleaner solution mixed with gasoline, per the instructions. Any thoughts from others who have done this?
I am most concerned with draining the fuel bowls properly and then getting them filled with cleaner and draining again. Words of advice are appreciated!
What bike? Are you asking how to fill the bowls with the Yamaha stuff?
79 GL. Yes, I am asking about how to do the procedure. Mostly, how do I draing the float bowls and how do I "tap" them since it seems impossible to get in there with a rubber mallet of even a small size. What have other people done?
I never did the procedure, but I suppose you could remove the float bowl drain screws (the brass one's at the bottom of each bowl) to drain the gas. After re-installing the drain screws it would probably be best to pour the gas/cleaner in via fuel hose closest to the carbs thereby avoiding the fuel pump. I'd use a syringe to do it rather than a small funnel.
I don't know about the tapping, but if you wanted to tap on the bowls a bit you could use a long extension or dowel with a very small hammer.
