I own an '85 LTD, and I recommend staying away from it at all costs. There are no positives to the fuel injection, and a truckload of negatives. Starting with NO PARTS. Both my reed valve assemblies failed (rotted due to age) and are no longer available. I ordered some used ones from a reputable online place, and they tyrned out to be just as bad as what I had. I am now trying to rig something. Many other fuel injection parts are also no longer available, and while you can sometimes find used ones, they will probably be no better than what you had. In theory it is a simple system, I've had mine completely apart. It is just as easy to work on as carbs, but again, NO PARTS ARE AVAILABLE. Mine is sitting in my back yard right now partially disassembled while I try to figure out what to do with it.
Another issue with the LTD is the charging system. The Interstate and Aspencade stators put out 350 watts, which is plenty. The LTD stator puts out 500 watts, which is simply too much for the regulator to handle. It gets red hot, burns up the connectors, then when you solder everything together, it will start burning the insulation off the wires close to the regulator. Mine even has melted plastic on the inside of the fake tank from the regulator getting so hot.
If you are interested in all the features, none of mine worked when I bought it. The stereo, cruise control, self leveling system, and trip computer were toast. True, Mine obviously sat out in the weather for many years. Then there is the digital dash. I have had intermittent problems with it cutting out, weird readings, and finally the speedometer completely failed. There is over 20' of rubber hose on the fuel injection system, in several different sizes, and all mine was rotted and leaking. I know some are in better shape than mine, but the fact that the replacement parts I got were just as bad as what I had suggests that deterioration is common on these bikes. I say stick with carbs all the way. The fuel injection doesn't do anything any better even when it is working right. I am seriously considering going to carbs on mine. The engine has 93,000 miles, but runs, (or ran) great, and has good compression all the way around.
With 102,000 miles on yours, unless it's in bad condition, it's only halfway worn out. Ride it another 100,000 miles while saving up some money to get something that is actually better.
BTW, if anyone could point me to a source for GOOD fuel injection parts, I would definitely appreciate it. Jerry.
