1 - 20 of 26 Posts
What's your preferred methods to secure your trailer while traveling and staying at a small hotel, etc.?
I have the ball part of a hitch mounted (welded) to a stand that I use to keep the tongue off the ground. It locks in place with a key.
I have also made and installed a cheap battery operated 120 db tilt alarm that goes off if you bump the trailer hard or it gets tilted enough to remove the stand. It's armed/disarmed by remote.
It's ear piercing and the nice thing about having all LEDs on the trailer is that I get it to flash/strobe the trailers lights... all of them when the alarm is tripped.
You can pick up small little alarm stuff like this less the ability to flash light at Radio Shack and some other places.
Tim
Oh... I have seen many other people chain their trailers to trees or posts with chain.
However I don't want to carry a large amount of chain with me that big enough to struggle to simply or easily cut.
Tim
Xenforo vehicle detail line
If the hotel stay is just overnight, I never take the trailer off.
in fact, the trailer has not been off my bike's hitch since a week before I left home to go to Virginia.
the hitch is tightened enough that it will just barely slip down over the ball, and then when the hitch coupler latch is down and locked, I put a padlock thru that so it can't be removed.
and the Safety Chains are wrapped up and over the top of the hitch and the padlock goes thru one of them also.
gonna be a real effort to get it off my bike....
I like the Alarm idea too, in fact, every time I went to bed, I was thinking "hey bud, you need to install an alarm on that trailer" and then you could go to sleep knowing that it is not messed with.
I also have a full cover for the trailer, it is made for trailers, and it has the elastic around the bottom to hold it secure. Not theft proof, but it has never once been messed with....
on the bike, I have a new Half Cover that goes over the windshield and shelters...
then I have a 30 year old POS looking full cover that I secure underneath the bike with a piece of hookup wire.... no locks, then you can't tell if it is a brand new bike, or an old guy's piece of junk under there....
that old cover is really ratty: my idea is "out of sight, out of mind" insurance.
and it also, has never, once in 30 years has that old piece of crap been messed with.
folks just don't have time to mess with farm junk, and that is how I disguise my bike when left alone.
I have been in every state except Alaska, Hawaii and North Dakota on a Gold Wing pulling a trailer. Like AZgl1800 I usually do not unhook it when I get to a motel. Back the bike into a space or ask and most motels will let you park it by the office. I really think people overthink the "SOME ONE WANTS TO STEAL MY STUFF" thing. But a simple daplock on the tongue will do the trick.
Joe, at the last 2 of the 3 hotels I stayed in, I was told to park it under the canopy where they could see it from the front desk.
At the last hotel, they have parking slots directly in front of each room's door.
This was a Day's Inn at Forrest City, AR.
I was shocked. I threw the covers over bike and trailer and went to sleep.
Banned
anything that locks the coupler together with the ball- a simple padlock, or better is Johns method
of using the existing trailer chain and padlock = will keep the casual thief away.
If the Pros want it- its gone!
a knowledgeable person will realize that there is only a single pin under the fender that holds the vertical receiver mount to the bike.
That can be wiggled out with a lot of effort, as the tongue has about 40 lbs sitting on it.
At first, I thought that was too heavy, and then I just increased the rear spring setting from 15 to 25, and the effect of a trailer behind me just simply vaporized.
I have to look in the mirrors to see if it is still there.
at the Rest Stops along the freeways? most of them have a large area where you can practice your tight figure 8s. I was doing that at one of them, and got a hand clap from someone who was watching.
I could not even tell there was a trailer behind me on those figure 8s.
and that was precisely why I was doing it.
I wanted to explore the outer regions of handling with the trailer hooked up.
It became evident to me quickly, that I can just ignore it, other that at gas pumps I stay 2 feet further away than usual. But, that is the only difference in the way I ride the bike.
I do not notice it on super tight twisties at all, it as if it is just not there.
It has never pushed me hard into the turns, I practice coming into the turns with a slight bit of braking lever/rear and just a touch of extra power.
That for some reason, makes the whole rig feel like it is riding on Railroad Tracks.
I just completed 3,335 miles with that trailer, and never once unhooked it. Still haven't and might not at all.... the whole thing will fit in the shop as is.
Locks + .45 ACP. If that don't do it, there's always insurance....
Locked up like this?
This is just exactly how my trailer completed the 3300+ mile ride.
The unseen part of that rigging is the hitch pin, and the two clevis hooks that connect the chains to the hitch.
all of it can be undone in 30 seconds, and the trailer towed away, hitch & ball, chains and all.
Making it look tough, might be all that is needed.
Kinda sorta. If I have to leave my trailer hooked up somewhere I use Buffo hardened locks and hardened logging chain, not light chain like you have, and not tight or near the ground, just slightly slack. Hard to cut hardened locks/chain even with good bolt cutters with just your arm strength. And, if somebody is that tough and wants it that bad, OK, it's all over-insured anyway. And if they happen to wake me up with the noise, then they are in for a few minutes of excitement! I'm not gonna shoot someone over a motorcycle trailer; I mean the sucker isn't full of gold bars or something. I will hold them steady while I call for the LEOs to take it from there. And, I've never had anybody mess with my Wing or trailer.
I have the super hard cable that is sold to keep motorcycles and trailers secure.
the key for it is on my bike's key ring.
I have never, ever used it. Carried it for years, just in case the trailer is left behind at a hotel, etc.... but, I normally leave the trailer attached to the bike.
I think the "look tough" has more effect than anything else we do.
also, for the bike, I used a Half cover for rain protection, and over that I throw a 30 year old piece of garbage looking full cover that encloses everything down to and under the belly pan... once that is on, no one that I have observed even gives my rig a 2nd look.
I also have a cover that is made for trailers, it is square and has the heavy elastic band to keep it from blowing off. I have never found that to be disturbed. It is not tied down, just the elastic holds it in place.
I've traveled all over the country with my CycleMate trailer. I've got a tongue lock and that's it. People don't usually mess with it or I could just lucky that nobody has.
Rudy has a very loud 130 dB horn that he uses with a motion detector.
might add that to the mix, placed on the bike so if either the trailer or bike is bumped, it will trigger and let you know something is going on.
Just Winging It
Over the years only thing I've ever noticed that someone touched was my kill switch.
I never touch the thing myself but I always look at it before I start the bike.
John they sell these.
Jeff,
I used to have one of those back when I had a big dually pickup.
the receiver bar that was on that thing cost over $150 and I worried that someone who knows what a 10,000 lb hitch really costs would steal the thing.
so, it had a locking pin like that.
probably overkill for our bikes, but you just never know until a trailer is gone that you wish you had put one on. :(
Super Moderator
When I stop at a hotel I back the trailer up to the curb and leave it hitched to the bike with a paddle lock through the hitch. When I'm camping and the trailer is set up, I have a wheel lock that I put on one of the tires and it locks the wheel. Has worked for me...... So far.
If the pavement slopes uphill towards the curb, I pull in forwards.
If curb is downhill, I back the trailer in.
Yup!
I had my bike take a nap on me at a gas pump once as I didn't realize the concrete apron I was parked on was sloped a bit and when I got off the bike it took next to nothing to move the bike forward and then clunk.
That extra weight really pushes. Now I leave it in gear.
Tim
I leave it in Reverse:
1st gear don't always stop it from rolling.
Been burnt on that one.
the last time I tried to pick up ole yeller, I could not do it anymore.
1 - 20 of 26 Posts
