1 - 3 of 3 Posts
What would you recommend tire pressure should be for an Escapade trailer with 4.80x12 tires?
Old School Guru
About 20-25 psi is about all that is needed unless your really loaded down. Those tires will take up to 60 psi, but unless you want it bouncing 4 ft into the air at evey bump, keep it under 30 at the most. I've towed my trailer over 10k with 25 psi and usually well loaded, and never a problem, even at 90+ mph.:smiler:
Gene:action:
i have 12inch tires on my trailer and i ran them between 20 and 30psi
you may have to adjust the pressure we went on some pretty bumpy roads so i stopped and let air out to around 20ish psi after that longggggggggggggg strech i re-adusted them back to 30
1 - 3 of 3 Posts
