1 - 9 of 9 Posts
I have a 4 wire plug on trailer, I have turn signals, running lights but no brake lights. I was told to tie brake wire to running lights ,when I did it blows a fuse. do I have to buy a converter . 1500 Interstate 95. Thanks for any help.
Senior Guru
hi and welcome to the forum with 4pins one has to be an earth that would cause your fuse to blow you need 2 for turn signals left and right 1 for running lights and 1 for brake lights + 1 earth i suspect the trailer is not wired for the brake
I and others have posted numerous threads concerning trailers trailer wiring and trailer isolator/converters. Use the forum search function and you'll find most of them.
I have to agree with the advise on the ground. I noticed that all the lights on the trailer worked fine, but when I hit the turn signals all of the back lights started blinking, looked like emergency flashers. I cleaned all the connections and it still did it. I re-did the ground and that cleared it up right away.
Senior Guru
quote from oxford english dictionary [ground] the solid surface of the earth, [earth]electrical connection to the ground unquote:cool:
Quote from Texas History. "You can all go to hell, I'm going to Texas". Davey Crockett
******* chip, check this thread out. I think it will answer your question. When you get a chance, could you please add your location to your profile?
Thanks,
Mike
http://tiny.pl/s1kc
1 - 9 of 9 Posts
