1 - 20 of 21 Posts
:readit: Been thinking of this for several months and I figured would make nice winter project. I want to put training wheels on my 1500. Just to much bike for me to be fun. Plan on using 1 1/2 square stock attached to already existing trailer hitch. Will use torsion half axles 425 lbs. and 12 inch trailer tires. Plan on using aluminum diamond plate to cover the "bones". With the trailer hitch attachment, I will use two other attachment points just back of passenger pegs. If you have any great ideas, please share them with me. Will try to remember to take pictures as I progress. Nothing ventured, nothing gained.
Sounds like more of a home made 4 wheel trike kit, not a bad idea, but if that's what you're going for I would have two concerns. First, what's you're plan for suspension, I wouldn't want them puppies rigid. And second, what's the wall thickness on the square tubing? I would think 1" oughta do alright, 1.5 is pretty bulky, isn't it?
I could be misunderstanding your plan, just throwing it out there.
Tubing is 14 ga. The half axles are torsion, so they have some give. Didn't want to use solid as afraid of getting training wheel on rock and lifting my rear wheel to high for traction.:smiler:
02 GL1800 w/Auto Pilot
most trailer hitches attach to the saddle bag supports.
those are not made to be a suspension piece, or to support more than 20#
You need to be attaching to the frame of the bike, not to any of the brackets that are bolted on with very small hardware.
Yeah, if it were me I'd probably go with a smaller tubing that had a heavier wall and I'd try to either hook it from the frame like a cradle set upor maybe even the swing arm to utilize the suspension on the bike. That said, if it doesn't cost too much you could go ahead and build what you're planning and hook it up and just see how strong it is. Just make sure you don't actually ride it until you're REALLY confident nothing will buckle.
I think those aftermarket ones are called Voyager kits? You may wanna see if someone can send you some pics of one of those so you can patern yours after that. It may at least give you some inspiration on the hook-up side of things.
Monkey with a Football
The voyager kit is basically a surrounding, triangle shaped trailer with a hitch that does not allow axial rotation except from the flexing of the arms of the kit itself. So I when I refer to trailer wheels, I'm talking about the Voyager wheels.
The Voyager kit replaces the center stand with a 3/8" steel plate that has welded 3/4" thread tapped blocks hanging low for type 8 long bolts to pick up the arms that go to the back of the bike forming a surrounding, triangle shaped trailer around the bike which has vertical welded plates for the Voyager wheel mounts and bearings. There is no axle on the kit.
The large plate attached to the center stand mounts, is supported forward with two steel square stock bars that reach up and bolt up to the rearward engine mounts with longer bolts.
The main triangle trailer would bounce wildly if it weren't for the suspension added at the rear of the triangle. There two shocks are added that attach between the rear of the triangle on welded risers and down to two arms that reach forward from the rear triangle next to the shocks and go to the rear wheel axle. At the rear axle. plates are bolted on with rearward pointing slots and a roller mechanism.
The suspension arms have fork ends to ride on either side of the roller and around the vertical axle plates. This allows the axle to stabilize the suspension arms and still allow movement in and out as the rear wheel of the bike moves up and down.
There are also springs assisting the shocks and the whole assembly is designed to apply some downward pressure on the arms to keep the Voyager wheels on the ground under pre-load. This is rigid enough that to set the pre-load, you simply drive the rear bike wheel up on a 1x4 and set the arm's large u-bolts to the rear of the triangle bar.
Once tightened, the 1x4 is removed and the drop on the rear wheel is enough to put the pre-load pressure on the Voyager's trailer wheels. The shocks then dampen short term changes at the trailer wheels.
Almost all of the side to side stress is taken up by the arms of the kit and the forward plate (center stand and engine guards. Although some is also there from the rear wheel drop plates on the axle. But the job at the rear axle is suspension not vertical stability.
Due to the flexibility of the long triangle arms, the thing is like riding one of those plastic ponies on a big spring to me. But I am very heavy and make the bike center of gravity very high.
I liked the kit but the spring ride was a bit much for me.
Hope that provides a little engineering perspective for you on the Voyager design.
I am in no way affiliated with Voyager or any of it's competitors.
Edit: Correction on bolt size.
Senior Memory
The Voyager kit replaces the center stand with a 3/8" steel plate that has welded 1/2" thread tapped blocks hanging low for type 8 long bolts to pick up the arms that go to the back of the bike forming a surrounding, triangle shaped trailer around the bike which has vertical welded plates for the Voyager wheel mounts and bearings. There is no axle on the kit.
:shock: Whoa!!! I want you in my shop!
Rudy, Do you understand everything you know about this??
Well... there is a bit more to it but not much. Let me know if you want the rest.. :action:
Define "everything".
Discussion Starter #10
Appreciate all the comments. I plan on trying to break it before I get on the road. Pic of progress today
Old Broad
He should He had one @ one time.
Old Broad
SS, I'll try & load some pics for you. Angela aka fysty-1.
Here is the Voyager kit withoutnthe belly pan. I'll try & finf the manuals tomorrow & scan the full kit parts. also check out Insta-trike http://towpacusa.com/products/instatrike
Discussion Starter #13
Progress so far. Have frame built and attached. Got some questions for trike riders or is this considered a quad mc rider?:? I noticed you sure have to steer instead of lean. Enough at higher speeds to make your arms get tired. Is this normal? Our roads are humped, so trike tries to roll off road making steering a constant. Again Normal?
Just one of the guys
The steering would be normal. It is because of the caster of the front tire. It will want to go downhill on a crowned road and want to go straight if the bike is sitting straight upright. An EZ steer or similar kit which increases the angle of the front forks either 4 1/2 or 6% will take care of that.
I'm curious how you are dealing with suspension for the added on frame and wheels.
Discussion Starter #16
data:image/png;base64,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Using torsion axles from Southwest wheels
http://www.southwestwheel.com/store/showproduct.aspx?ProductID=3181&SEName=adjustable-425-lb-torsion-half-axles
Old Broad
Scoot, How are you fastening it to the bike?:? But It is looking good thus far. Good work.:applause::applause::waving::waving:
Steers just like a bike with a sidecar so exercise those arms and upper body, you'll need it.
My wife has a towpac on her 1500. To help in the steering. Soften the rear suspenion as much as possible. The kit tires are now supporting some wieght so the air shocks can be lightened a bunch. I normally run 15 pounds in hers. Helps the handling plus ride is smoother. One other thing. You might want to run a brace from the 1 1/4" box on your hitch up to the cross frame just above and behind your liescenes plate plastic panel..
1 - 20 of 21 Posts
