Too gentle a shift when you shifted up into OD. If it never happens again, then put it down to a bad (gentle) upshift and don't worry about it.
I've done it a few times where I didn't QUITE shift it firmly enough, but it went in...until I come off the throttle, at which point it jumps in between gears, and I find myself effectively in neutral. A good firm shift fixes it.
If it starts happening all the time, it could be worn dogs in the transmission.
