I need some advice. I finished replacing my head gaskets because I was getting coolant in the cylinders. Put it all back together and now it won't turn over. I can hear the starter try, but it makes no progress. I then discovered that unless it is in neutral, the back wheel won't spin, regardless of clutch pressure.
I'm pretty sure that I didn't mess up the timing when I pulled the heads, and I really don't see how I could have broken it. It would turn over before I took it all apart.
Where should I start trouble shooting?
