41 - 60 of 67 Posts
Monkey with a Football
Firefox again, just now turned OFF "NoScript" to see if that is doing it, it was just turned on last night before I went to bed.....
I used to use NoScript but it got too needy all the time so I switched to Ublock Origin.
Life is easier now.
Discussion Starter #44
I have uBlock Origin installed, and for some off reason, it was Disabled....
I fixed that, turn off NoScript and Enabled uBlock Origin again.
now, things are working right again.
Discussion Starter #45
simple editor test for extra white spaces between lines
turned off the WYSIWYG editor function
there should only be 1 white space between all these line
dum
dum
dee
dum
Discussion Starter #49
testing Image sizes, Reference to what the post displays
100x111
320763
250x300
320764
550x600
320765
It appears that Xenforo does NOT upscale the images, so we need to scale the image to the size we want before posting it.
this gives us exact control of how it displays.
Discussion Starter #55
all of that is done in GIMP with some special Python scripts.....
right now, I am just looking at what they can do......
I will feel like the king, if I ever figure out how it works.
Discussion Starter #57
Questions about font color.
You can use the MS DOS color command to change font colors.
To make font color to be red.
To do this type the following and put square brackets [ at the start and ] at the end around the phrase ‘color=red’
Color=red
Next right after the color phrase ] bracket, type out your message. At the very end of your message,
type the left bracket symbol and the ‘phrase’ “ /color “ followed by the right or End bracket symbol.
just remember, the color phrase must be enclosed with [ ..... ] bracket symbols
Below are the commands for some colors.
= Black
= Gray
= Blue
= Light Blue
= Green
= Light Green
= Aqua
= Light Aqua
= Red
= Light Red
= Purple
= Light Purple
= Yellow
= Light Yellow
= White
= Bright White
Be aware some colors will not show up depending on whether you are in "Light Mode" or "Dark Mode."
Discussion Starter #59
scw189 Level 1
Level 1
Posts: 4 Joined: Sat May 04, 2019 8:28 am Contact:
Contact scw189
Libre Office - Calc Unwanted interaction with Firefox
Unread post by scw189 » Wed Feb 12, 2020 2:15 pm
I just discovered some type of interaction between Firefox and Libre Office -Calc. If you leave a spreadsheet open in the background and you go do a Google search (under Firefox) and your search process involves a cut and paste (cntrl C/ cntrl V) operation, what ever is in the paste buffer get also pasted into the open spreadsheet in what seems like random locations. This happened previously to me and a spreadsheet wa
41 - 60 of 67 Posts
