Trike tyre pressure
6136 Views 7 Replies 4 Participants Last post by  MICK
Hi,
Does anyone out there know what the tyre pressures should be for a GL 1500 EML
BERMUDA TRIKE. Also what air pressure should i have in the rear suspension, for
both solo and two up. [with 70kg rider, 55kg pillion.] Thanks.
Mick
Ask these guys, I don't think we have many trike guys on the forum.
http://www.colinappleyard.co.uk/motorcycles/goldwing/trikes.htm
ello fellow trike rider :waving:
aint three wheels jus sooo much fun
i run at 35lbs in front and 20 in back
tyre wear is very good btw
tho there was talk of being able to run down to 14lbs in rear to iron out a few mo bumps ive not tried that
i saw a fax from EML confirming this but i think find a pressure that suits u and ur pillion
GURUS i see there are no trike smileys puleeze amend :gunhead:
Thanks for info. its near enough to what i am running at now, [32 front, 21 psi rear]
I understand that you can run the rear anywhere between 14 psi & 28 psi which seems to me a lot to play about with, so i thought i would go for 21 it seems to be about right.
As for the rear air suspension, solo i run at zero, two up i run 10 psi does that sound to be ok? [We are only lightweights]
We bought the trike back end of summer so i did not have much time to play around with tyre pressure & suspension before it was put to bed for the winter.
ROLL ON SUMMER,
Mick.
HAS SHE BEEN SERVICED RECENTLY
AIR FILTER, PLUGS,OIL +FUEL FILTER, COOLANT
I DID ALL THEM OTHER WEEK AND SHE RUNS SOOO SWEET NOW
ITS A GOOD IDEA TO HAVE A BASE LINE TO WORK FROM WHEN U BOT THE BIKE
ARE U A MEMEBER OF YORKS GWOCGB IM IN YORKS TOO NR BRIDLINGTON
JUST TRYIN TO WRANGLE INSURANCE QUOTES AT THE MO
FRONT TYRE PRESSURE IS CRITICAL MUCH LESS N U NOTICE CHANGES TO STEERIN HANDLIN
U WILL FIND OUT WHAT TO RUN AIR SHOCK AT WHEN U GO OVER A SPEED BUMP ON A CARAVAN PARK U CAN FEEL THE BOTTOMING HAPPEN
MY FIRST LONG RUN O YR IS TO SCOTTISH BIKE SHOW MARCH 11TH
Mick, mid-20's psi is accepted by most trike builders and buyers. It's supposed to be better as it helps prevent the back end hopping all over the place and skipping in turns etc.
Thanks GW Eddie for your advice.
The Breeze, just had a service done, just waiting for the sun to shine. I am in the GWOCGB soi may see you at a wingding. I visit E. coast fairly regularly , i will send you a PM before my next trip.
