Thanks for info. its near enough to what i am running at now, [32 front, 21 psi rear]
I understand that you can run the rear anywhere between 14 psi & 28 psi which seems to me a lot to play about with, so i thought i would go for 21 it seems to be about right.
As for the rear air suspension, solo i run at zero, two up i run 10 psi does that sound to be ok? [We are only lightweights]
We bought the trike back end of summer so i did not have much time to play around with tyre pressure & suspension before it was put to bed for the winter.
Mick, mid-20's psi is accepted by most trike builders and buyers. It's supposed to be better as it helps prevent the back end hopping all over the place and skipping in turns etc.
The Breeze, just had a service done, just waiting for the sun to shine. I am in the GWOCGB soi may see you at a wingding. I visit E. coast fairly regularly , i will send you a PM before my next trip.
