1 - 20 of 26 Posts
hi happy st.patty's day. i just spent 5 hour's trying to syn my carb's on gl1100 . fluid keep's shooting up out of site, can't see to balance at all. any idea's on what would cause this . they just won't balance.
i'm using a new sync pro from sync master. all4 i guess
i get one to lower down and number 3 shoot's up and 1 &4
they are all out of wack
Sounds like your idle is going up too much during the process.
On the 1100's No. 3 is the base line carb, so you adjust No.1 to No.3 first, then use the center adjuster on the left side to balance No. 2 and No. 4 together, last use the adjuster on the right side of No.4 to balance the left side carbs with the right side carbs.
http://www.randakks.com/TechTip44.htm
thank's this makes sense. now i have to wait till tomorrow night to see if this will work
Guru
Make sure your idle is down around 1000. Does your needle flutter like crazy? If it does, you must lightly squeeze the vacuum line just a lil to smooth out the needle so you can get a good reading.
If you have the new blue-fluid syncpro, do you have the restrictors installed in the vacuum lines?
That was going to be my question.. Missing Restrictors..:rollingeyes:
Discussion Starter #10
needle does flutter, will try squezzing the line.
idle is right 1000 rpm, but fluid shoot's high, have to shut off bike or it will get sucked into the motor.
I use a set of vacuum gauges sold by J C Whitney and the restritors are actual valves that can be adjusted to smooth out the bounce of the needles. Will your restritors close all the way? Are they adjustable?
I hate a fluid gauge, best place for them is the nearest landfill. You will have to install adjustable valve on each line or change the medium of the fluid so it is not so sensitive . Even if you have the lines restricted properly and pull one off the engine will suck the fluid out of the gauge before you can blink your eyes, leave one hooked up and pull one and away goes the fluid.
Old technology, time for new .
The Carb Tune works well for the smaller wings (will not work in the 1500)
The best all around is a set of simple vacuum gauges.
Kit
Discussion Starter #13
hi again. i agree but to late i already have it bought.
i got all the kink's worked out but a small problem.
i loss some fluid from the sync. is there an another fluid i can use to fill the snyc pro with? is tranny fluid a good alternitive?
I made a manometer for my Motoguzzi using Marvel Magic Mystery oil.
02 GL1800 w/Auto Pilot
Any light oil would do fine, say sewing machine oil. Etc...
I loaned mine to a friend - and soon after had to buy a bottle of the fluid.
If you buy the "right stuff" buy two while you're at it.
Discussion Starter #19
tranny fluid it is just filled it. not going to china to buy blue fluid :) the book said hook it up to number 1 to set the sync pro. that incorrect it has to be set to numer 3 that is why it was shooting up all the time after i set to number 3 carb it set perfect and , almost completed the sync.
thank's again for your help everyone.
The gauge is designed so that it works on most bikes. Manufacture doesn't know what your going to use it on, plus the translation to English usually leaves something out. Just happens the goldwing's #3 carb is the fixed one.
Other bikes may be different although my xj650 also balanced everything to the # 3 carb.
1 - 20 of 26 Posts
