First…. welcome to the forum!!
This is a 'fairly common' problem. Usually bleeding the front-left caliper will result in some pressure at the pedal but you might have to bleed the entire system. The miti-vac might not be operational so try pumping the pedal. Use the 'pump-hold-release' method and see if pressure builds. Bleed the front caliper and then the rear caliper. Make sure to use some fresh Dot4 brake fluid and refill the fluid reservoir as needed.
