· Still Learning
Have you replaced the battery in the fob yet? Might be time to.
· Gregarious Greeter
Your trunk controller should be in the trunk lid seen after removing the inside cover. Make sure all is plugged in. My wing is a 2005 and have not changed the battery in the key fob yet, but that would be the cheapest and easiest thing to try first.
I was having trouble with mine (2009) so I took it apart and here is what I found... The mylar substrate (membrane) that is actually the push switch had moved off the PC board a bit for some unknown reason... I carefully repositioned it with a small tweezer and it works just fine now... If the new battery doesn't take care of it, you may want to check that switch substrate...
Les
· Still Learning
Les
Is that in the fob or the trunk unit Les?
In the fob Stu... When I started having problems, the detent didn't feel right when I depressed the button so I opened it up to see what was going on...
Les
