1 - 1 of 1 Posts
Hi all like abit more presence on the rear:cool:put side lights in the trunk.
This mod is for people in uk/europe as lights are readly available in US.
Ordered 2 rear indicator bulb holders from honda £10,these alreadycome with loom & 4 pin connecter.Removed trunk rear cover,this reveals 2 pin connecters on loom.Open trunk,remove bulbs covers in either corner,then remove rubber bungs from light bulb holders.
Indicator bulb connecter as a 4 pin connecter, but only 2 pins are used pushout the pinwith small screw driver.then replace in the one that corresponds with the 2 pinconnecter under trunk,these can then be connected.5 watt bulbs,obtained at bike-automotive shops.Working fine these can be screwed into trunk bulb holders.Everything can be then be refitted.Cheap quick easy modification that gives a bit more presence on road on darker days-nights;);)
1 - 1 of 1 Posts
